11.10.2008, 12:26 AM
Originally Posted by e-mike View Post
i know that im off topic...sorry for that... but the mmm is not rated for 200amp continiously??????
Not unless the "special project" MMM is different than the regular one. Could be I suppose, but I haven't heard anything that said different. The 200A rating was just a rumor AFAIK during the time where it was still in development and everyone was speculating on its ratings.
If my understanding of an H-bridge is correct, in order to see the 360A rating, you would need an external ground directly back to the battery. The controller's bridge would not be able to conduct through the motor both ways (internally) if all three FET banks were being used to realize the 360A output. I'm sure I'm missing something here...but it sounds correct in my head.
This is how I see it: The MMM has 36 FETs. 3 phases of 6 FETs for the positive supply, and 3 phases of 6 FETs for the ground connection. At any one time, 6 FETs are conducting power to a coil, and 6 are conducting to ground at the other end of the coil.
In brushed mode with reverse, one phases is not used at all, so the same basic operation as above is used.
In high-power brushed mode, the battery + wire goes directly to the motor + terminal, and you tie all three phases together for the ground wire. Since there are 3 phases of 6 FETs on or off at once, that's 120A X 3, or 360A.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.10.2008, 12:31 AM
Yes! I just thought of it with inverse polarity (external gound, not external positive).
Pdelcast
Pdelcast's Avatar
11.10.2008, 02:06 PM
In brushed mode about 100A for forward/reverse (and that's a REAL 100A continuous, not a BS 20 millisecond rating like "Brand N" would give you.) The limitation is really from the 10ga wire -- 100A is about the limit for a single 10ga.
A good quality brushed motor will melt at about 40A continuous, and will really only handle about 25A or so on a continuous basis... so you should be OK with up to 3 540 size motors in parallel.
In high power mode, you should be able to run a little over 200A continuous (remember - - Amps doesn't scale linearly because of the I^2 losses...)
Patrick del Castillo
President, Principle Engineer
11.10.2008, 04:49 PM
...not a BS 20 millisecond rating like "Brand N" would give you...
I just re-read this section and wonder if the letter "N" was just a coincidence, or is it referring to a certain competitor whose name begins with "N"?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.10.2008, 06:26 PM
I don't think there is a company named Novak. Wait, lemme check... there is!
Area 52 Ranch Raceway
T.R.C.R.
sikeston34m
sikeston34m's Avatar
11.10.2008, 06:49 PM
If 100 amps is the limit for a single 10Ga. Wire, What does this say about the 100 amp + continous ratings of other brand ESC's that are fed with 12Ga. Wire?
e-mike
e-mike's Avatar
11.10.2008, 05:11 PM
i always tinking that the mmm was very powerfull only 120amps....so what is the real amp rate of the mmm (in brushless mode)so i read some thread here and im surprised to read that the mmm can old 100amp in brushed mode and 200amps in highpower mode
D8t on juice!!
