What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.10.2008, 12:31 AM
In high-power brushed mode, the battery + wire goes directly to the motor + terminal, and you tie all three phases together for the ground wire. Since there are 3 phases of 6 FETs on or off at once, that's 120A X 3, or 360A.
Yes! I just thought of it with inverse polarity (external gound, not external positive).
Pdelcast
Pdelcast's Avatar
11.10.2008, 02:06 PM
In brushed mode about 100A for forward/reverse (and that's a REAL 100A continuous, not a BS 20 millisecond rating like "Brand N" would give you.) The limitation is really from the 10ga wire -- 100A is about the limit for a single 10ga.
A good quality brushed motor will melt at about 40A continuous, and will really only handle about 25A or so on a continuous basis... so you should be OK with up to 3 540 size motors in parallel.
In high power mode, you should be able to run a little over 200A continuous (remember - - Amps doesn't scale linearly because of the I^2 losses...)
Patrick del Castillo
President, Principle Engineer
11.10.2008, 04:49 PM
...not a BS 20 millisecond rating like "Brand N" would give you...
I just re-read this section and wonder if the letter "N" was just a coincidence, or is it referring to a certain competitor whose name begins with "N"?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.10.2008, 06:26 PM
I don't think there is a company named Novak. Wait, lemme check... there is!
Area 52 Ranch Raceway
T.R.C.R.
sikeston34m
sikeston34m's Avatar
11.10.2008, 06:49 PM
If 100 amps is the limit for a single 10Ga. Wire, What does this say about the 100 amp + continous ratings of other brand ESC's that are fed with 12Ga. Wire?
