stum
11.11.2008, 08:58 AM
Originally Posted by DRIFT_BUGGY View Post
Well I checked over the drivetrain today and it all seems normal. I put a 12T pinion in and changed the start power to medium but won't have a chance to give it a proper run till tomorrow. I took it for a quick run in the street and it doesn't to long to get to top speed. Probably be under geared now for the track. I do notice how ever that when the motor is connected to the spur the buggy is alot harder to push and when driving it sort of feels like I am running drag brake but I have that dissabled
That maybe your issue.. you are calculating your speed wrong.. use 43/13 (3.30:1) for the 8ight buggy. At 12t you are at 44mph that is the top you would ever want that motor at iMO. To be honest 11t is a better starting point here is the calc. Looking at it the 3d would be a lot better for you on 5s as it would allow more gearing options, I don't even know if you can do an 11t pinion, at least with the Tekno v3 conversion I'm limited to a 12t as the bottom and it bearly meshes up. The 3d on a 14t is 40mph, then you can tweak up or down some... but I wouldn't buy another motor myself I would make do with the 2.5d at 12t and be happy, gearing down from what you had should reduce temps worst case run a fan on it during high heat summer. Just my2c
Just anyother tip... I run my Medusa v2 60mm 2000kv with a 15t on 4s lipo racing at 41mph at about 130 all day.. I'm sure your Neu could do the same! No nitro can even come close to me.. unless I screw up and my 4s 5k packs get 17-20minutes of non-stop racing :) LOL Just move down to 4s lipo and keep your 15t and be golden :) 4s lipo is the typical max in most sanctioned racing events anwyay (at least for now). You can usually get away with higher voltage at league races though.
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 11
Total Voltage: 18
Motor KV: 2050
Tire Diameter (inches): 4.5
Tire Ballooning (inches): .5
Motor Current Draw: 80
Motor coil Ω: 0
Spur/Pinion Ratio: 4.36 : 1
Total Ratio: 14.43357 : 1
Tire Circumference (inches): 17.28 inches (438.88 mm)
Total Motor Speed: 36900 RPM
Vehicle Speed: 41.83 mph (67.2 km/h)
Estimated Adjusted Speed: 40 mph (64 km/h) - 5% loss
Effective KV Value: 2050
KT constant: 0.66 oz-in/A
Motor Torque: 0.27 ft-lbs
Final Torque: 3.97 ft-lbs
Final Power: 1440 watts (1.9 HP)
  • 12t-43mph
  • 13t-46mph
  • 14t-49mph
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.11.2008, 04:12 PM
Other Ratio: 1
Total Voltage: 18
Motor KV: 2050
Motor coil Ω: 0
  • 12t-43mph
  • 13t-46mph
  • 14t-49mph
Im running a 46T Spur. I checked the manual for the Losi ESC/Motor and they recommend a 12T Pinion when running a 45T Spur on 5S with the 2100KV motor.
My ESC temp is 130F and battery is 120F
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
stum
11.11.2008, 05:23 PM
What were you geared before? A 12t on a 46t spur is about 46mph on the 8ight buggy with a 5s lipo.
