Just bend the heat sink fins away from the bullits, put some shrink tube on them & run it. At some point Castle will listen to us about this problem (& the fan wire issue).
and then they void your warranty and your stuck with a dead v3
Talked to CC. Tech support guy agreed that it was probably a short accross the heat sink. They are sending me out a replacement. He told me to open up the case and just put a little shrink wrap around the 6.5mm socket. But there isnt any room to do it. Its tight against the plug. Looks like they are using the solutions developed on here as their tech support solutions now. LOL
Hopefully this one is good. I'm really getting tired of this.
to make it...
or break it...
good to read..i hope cc could fix this kind of issue
