Ryu James
Ryu James's Avatar
11.13.2008, 06:17 PM
Originally Posted by patxeik View Post
hi all
Since i converted my revo with the tekno conversion i just think to convert all my nitros to bruslee. Now i have a mugen mbx5t coming up to me the next week and i need some information about the conversion hardware,.....
1- which motor use?
i already have a Tekno RC Edition Neu 1515/1Y/F Motor (5mm shaft, 110A, 2200kv) will be faster enought for the truggy with 4s lipo?
2- i will use 4s 5000mah lipo, will fit on the battery tray.
3- which motor mount use for my neu 44 o 36 mm?
4- how many brace i will keep from stock? i think just the rear one, and the others are made from plastic or nylon? will you made an aluminum upgrade for those parts?
Anyone have more pics of the conversion, i wanna see how the motor mount move into the chassis to atack the spurgear
OK, those are all my questions by the moment, more comming soon
4s will be ok with that motor but i would run 5s. i run 5s with my Neu 1515 1.5D 2700kv and it is insane fast. the motor stays cool too. 5s on your 1y will give you speeds in the 50mph range iam guessing. a bit faster than nitro. 4s you will be same as nitro speeds. view this page for setup info.
http://www.impaktrc.com/product_info...oducts_id=3276
the tekno kit comes with aluminum chassis braces so you should be fine there
if your neu motor has finned can then you need the 44mm mount and if its smooth can you need the 36mm mount.
Jammin SCRT10 Neu 1512 1y
Matthew_Armeni
Matthew_Armeni's Avatar
11.14.2008, 01:28 AM
44mm for finned Neus, 40mm for smooth can Neus, and 36mm for Medusas and Feigaos.
  Send a message via AIM to Matthew_Armeni
