Finnster
KillaHurtz
Finnster's Avatar
11.17.2008, 12:27 AM
What are the temps? Are you getting shut downs?
Getting a 80mm Medusa will not help. Its basically the same motor as a 1521.
You are spinning that motor very very fast. Beyond what is recommended. Lots of power, but lots of heat as a result as well. How many amps are you pulling, and what are the temps of the motor and esc?
Getting a lower kv motor and gearing up may be a better way to go than gearing down that setup.
