edep345
11.17.2008, 01:45 AM
Use the Castle Link -- and lengthen the arming time to the maximum. Then, after you have it calibrated, change it back to whatever you want.
Sometimes the Spektrum doesn't bind fast enough, and while unbound it sends "off" throttle to the Monster. The Monster thinks that it should arm - - so it arms just before the Spektrum binds. Lengthening the arming time should allow you to calibrate ...
I tried this-and got the same results, should I send it in again>?
