What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
11.18.2008, 12:11 AM
Absolutely.
11.18.2008, 12:19 AM
Also keep in mind the pinion spins much more than the spur does. So even if the material on both was identical the pinion would wear faster. Say you run 13/46 gearing, the pinion rotates 3.5 times more than the spur. So hardened pinon needs to be many times harder than the spur to survive...
brushlessboy16
brushlessboy16's Avatar
11.18.2008, 07:41 AM
very true linc, but that was after only 20 minutes of running
Patrick
Patrick's Avatar
11.18.2008, 10:54 AM
I had a non hardened pinion with a plastic spur for a couple of months with very little wear. One night at racing my mesh slipped a bit and melted the spur. My only spare spur was a steel one, so I decided to use it for the last race which is only 5 minutes. After 4 minutes the pinion had no teeth left at all and my car had no drive.
Tempted
RCM is smarter than me....
Tempted's Avatar
11.18.2008, 11:00 AM
Originally Posted by Patrick View Post
After 4 minutes the pinion had no left teeth at all.
As opposed to right teeth?
The answer is no. And yes, mine is faster.
11.18.2008, 11:03 AM
Gotta watch out for those left teeth!
riceman
RC-Monster Gold
riceman's Avatar
11.18.2008, 11:29 AM
This is why balance is very important! This happened to me when I had my motor and battery both mounted on the left side.
Patrick
Patrick's Avatar
11.18.2008, 11:54 AM
Don't know what your talking about, I don't see anything wrong with my post...
Tempted
Tempted's Avatar
11.18.2008, 03:44 PM
LOL!! You shoulda left it alone! It was funny!
brushlessboy16
11.18.2008, 03:58 PM
Thats not right, should just left it alone
Tempted
Tempted's Avatar
11.18.2008, 04:20 PM
Now I'm confused....
11.18.2008, 06:11 PM
Thats ok, probably happens to you often...right? You should be left alone to figure it out.
brushlessboy16
11.18.2008, 06:53 PM
If a tree falls in the middle of the woods and there is no one around to see it, which way did it fall, left or right
Tempted
Tempted's Avatar
11.18.2008, 07:56 PM
Actually the humor is the fact that some people don't get the humor
11.18.2008, 07:58 PM
Who cares? It is a tree.
