pasan
I <3 RC
pasan's Avatar
11.19.2008, 12:45 AM
3s lipo and low gearing would make for an interesting speed car. My tt-01 has limited gearing options, so high revving motor would be nice. And I have a MM and a 5000 3s 25c neu lipo too... Hmmm may have to give that motor a try. Wonder what they have changed over the old cs 36 motors?
A Sidewinder 4600 on 3S is more than enough for the TT-01 with 22/58 gearing.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
11.19.2008, 12:49 AM
To do what? I have currently done 74mph with a feigao 6s motor, 3s lipo and 25/55 gearing. That is the highest gearing I can achieve without making some custom stuff. I would like to see what I can do with the stock motor mount and spur before I get into modding stuff.
pasan
I <3 RC
pasan's Avatar
11.19.2008, 01:10 AM
To go fast of course. A 9000Kv motor on 2S will require tremendous power to propel the TT-01 to high speeds. The stock spur is not 55, and how did you manage to fit in a 25T pinion with the stock motor mount? I remember I was pressed for clearance when fitting a 22T with the 55T spur.
AX10 RTR - Stock :D
11.19.2008, 01:20 AM
You can get a 55t spur for the tt-01. The same set of mount holes for the 22/58 fit the 25/55, as the spur is smaller in diamter.
I will stick with the hacker b50 5s (7400kv) on 3s lipo to do my session of runs. Getting cooler out here and everything runs faster in cold weather.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2008, 01:28 AM
I'v been running my B50 5s with 3s1p in my pan car geared 54/12. Both mm and motor stay cool enough.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
11.19.2008, 03:05 PM
Is that lipo or a123?
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2008, 04:18 PM
Forgot to mention that it is with A123. I'll build me a flat 4s1p A123 pack and see how that runs. That should be more like a 3s1p lipo pack under load.
But figure that under "drift mode" the rotor is spinning abit over 60K rpm.
