jordan...
one.five.two.seven
11.19.2008, 08:39 PM
Well, i just put my order in for an MMM V3, hopefully it will be here in 3-5 days and we'll finally get to see this thing running
will keep you guys posted
jordan
11.19.2008, 09:07 PM
Woot!
MGM Troubles
SV6000
SV6000's Avatar
MGM Troubles - 11.20.2008, 05:01 AM
Hey Jordan what problems are you having with the MGM exactly. I have two 28025-3 and both gave me a lot of trouble to start with but all worked out fine. 9 times out of ten it was something i was doing.
So what are the problems. I dont think that your MMM will handle that motor 4.5Kw/22.2V=204.5A
the problems are...
jordan...
one.five.two.seven
the problems are... - 11.20.2008, 09:58 AM
First off, using the CC_03 cable with the USBcom++ to update the controller SW, the PC will not recognize the controller. So I cannot update anything as it stays stuck at the ‘searching for device’ stage. That is using the MGM flasher software by the way, downloaded from the MGM website.
Second problem is I cannot set the throttle points using the transmitter, or get the ESC into programming mode at all for that matter. I have read the various walkthroughs and instructions on how to do this, ie. Hold full throttle, turn on the transmitter. Turn on the controller/receiver and it should beep to let you know its going into programming mode, then put it to reverse, then neutral etc. But it does nothing. The only thing that happens is a green light turns on inside the ESC, but I get no flashes or beeps or anything else.
Another thing is that when I connect the whole system up, the steering servo will work, but the motor will not turn when I use the throttle. Which is a bit odd, because I think this proves the BEC is working, but somehow no power is going to the motor.
And I’m using the Spektrum DX3R.
Also, im only running 5s, (18.5v). I used Brians calc and i think the average continuous amps i'll be pulling should be alright for the MMM, fingers crossed.
thanks for any help, would be much appreciated
jordan
lutach
lutach's Avatar
11.20.2008, 10:08 AM
Are you holding full throttle for over 10 seconds?
feistyacorn
feistyacorn's Avatar
11.20.2008, 10:26 AM
Not sure if you have already tried it but, sometimes the throttle needs to be reversed on the remote before the ESC can be programmed. I have a Futaba 3PK and a MMM and I had to. Good luck! Awesome build!
jordan...
one.five.two.seven
11.20.2008, 09:30 PM
@Lutach: yep, held it down for a minute just to be sure and no beeps or flashes or anything
@feistyacorn: yep tried that, that was actually one of Mikes suggestions, still nothing though
cheers guys, any other suggestions would be awesome, i actually hope its something im doing so i dont have to wait for replacements etc.
jordan
