Smashwings
Smashwings's Avatar
11.25.2008, 09:02 AM
Yes, that's the solution I see too, but didn't thought it would be necessary if designed for a Revo. Looks like a faulty design?
teknorc
11.25.2008, 03:14 PM
Definitely not a design flaw. It's more of a tradeoff. Just like not being able to use long travel suspension setup with RPM arms. With added functionality sometimes comes tradeoffs. If you don't think you're going to use the additional Ackerman holes, they can easily be ground off for more clearance as jhautz suggested. You may find that under normal operating it may not be a problem even as is.
If the parts break for any reason due to grinding or other circumstances, just send them back and we'll replace them. Thanks!
Tekno RC - Performance Parts
Smashwings
Smashwings's Avatar
11.25.2008, 07:49 PM
But RPM arms are third party accesories , and the bump steer correction (hollow ball in the upper situation) is an standard adjustment that Traxxas include for the Revo.
But it's ok , some dremelling will solve it fast, thanks.
Semi Pro
Semi Pro's Avatar
11.28.2008, 03:12 AM
its also the adjustment that most of us who race our revos are useing, i think that is going to stop me from buying this kit.
riceman
RC-Monster Gold
riceman's Avatar
11.28.2008, 10:12 AM
That's a key point you just mentioned. The percentage of people who actually race their Revos I'm guessing is probably less than 10%. The majority purchasing this kit would be getting a definite upgrade in durability and performance with a direct bolt on. And as Tekno has mentioned with slight modification it still accommodates the serious racer setups without affecting strength.
