11.26.2008, 01:42 AM
Originally Posted by gtxracer View Post
Wow....great tech info linc! I never had problems on 4s in my two E-Revos, but I could see how a 1521 and high voltage could make some diffs explode. Way to go!
Thanks, I will get a diff built for the case and see how well the center driveshafts line up. The stock lst diff outputs should fit most cvds. The input will require a 8mm id cvd cup, or mike's adapter to use the stock sliders. I have those adapters so I will give them a try. I will test with a stock revo chassis and an erevo chassis.
11.26.2008, 05:49 AM
noob: is there anything Linc won't put an LST diff in?
me: hide your girlfriend
