brushlessboy16
brushlessboy16's Avatar
12.02.2008, 10:12 AM
haha. Ill just cut everyone elses tires on the track . Looking to run 4s 5000-6000mah.. The 2 zippie packs are still cheaper then any other. And my charger can only charge at 50 watts.... so 4 of the zippy 4s 3600mah packs are cheap. Im on my phone so i cant just open a new tab and check..
brushlessboy16
12.02.2008, 01:28 PM
How many Mah should I shoot for to run a 15 Minute Main?
4x4s 2500mah each pack is only $36 and i could get 4 of them.
100a continuous and 150a burst
The 2500mah packs are 123grams less-per pack then the 3600's.so total weight would be:
2x 4s 2500mah- 592g
2x 4s 3600mah- 838g
5s 4000mah- 627g
dirt101
dirt101's Avatar
12.02.2008, 06:00 PM
Originally Posted by dirt101
6s is pretty much useless at my track to but thats exactly the reason I ordered a 6s. haha, mo power is always better.
nope not always. i race my b4 and i toned it all the way down to brushed and now my lap times are way way faster than when i had a mm and 5700kv motor.
oh yeah I guess I should have mentioned that I NEVER race. I just play at the track.
rustler, lx2e, xxt cr
brushlessboy16
12.02.2008, 06:02 PM
I just ran the truck softly. was at 13 minutes with 3.7v left in the cells :)
(4000mah 5s)
dirt101
dirt101's Avatar
12.02.2008, 06:07 PM
2x 4s 2500mah- 592g
2x 4s 3600mah- 838g
5s 4000mah- 627g
If you think you can make the 15 min main on the 4000mah 5s I would go with that or maybe take a look at their 5000mah. I would stick with 1 larger battery becuase It simplifies things alot. With one battery you only have one to take on and off the charger, one to balance, and only one to mount to the truck. Trust me I have been doing the dual pack thing for a while now and im switching to a 6s ASAP. Im even more biased toward one large pack now that I use a 0610(your using the 0606 right?) and can only charge one pack at a time.
brushlessboy16
12.02.2008, 06:20 PM
Im using the Imax B5.
I doubt that the 4k pack will make a 15 minute main.. just no way
1 battery does simplify it but saddle packs would lead to better handling.
Im being told that 4s would be best for the 1y, i run 5s now but am unsure
dirt101
dirt101's Avatar
12.02.2008, 06:39 PM
I doubt you could feel the difference. I used to run my truck like this(3s on the velcro) and couldnt feel the difference at all.
3s setup
brushlessboy16
12.02.2008, 06:50 PM
Hmm I have my tray right up against the center dogbone and brace. I just cant make up my mind.
brushlessboy16
12.03.2008, 09:54 AM
can you guys be on the lookout for 3000mah 4s packs for me.
