Byte
11.28.2008, 07:37 PM
Originally Posted by wallot View Post
vendetta above 50km/h is very hard to control
I can get to 50km/h with my Neu 1105/2Y (5250kv) on 2S with 45/13 gearing
To get to 100km/h plus i would use 2S lipo, 45/19 gearing
one of the kamtec buggy bodies with high downforce wing
28-30mm wide foam tires to get as much traction a possible
since mamba8000 is a weak motor for vendetta and you need to use quite high gearing you would need to start rolling quite slowly
mamba8000 motor will burn on 3S doing speed runs
get Neu and Mamba Micro Pro
I haven't got a Mamba 8000 but a CM-2080, I don't know if there is a difference, but the only thing I can see that mine is expensiver than the mamba 8000..
Where can I find the Kamtec bodys? I only see a Mini-T body on their site..
Anyway, what about a MMM in the Vendetta? Wouldn't work, right?
