Outrunners and hard crawling don't really mix well. They cog a ton when a wheel gets stuck, and with large tires it makes it worse. Sensorless is much better suited for a scaler.
Those links and shock mounts would work if you don't want to fab anything. FYI the 3mm threaded ballends will break pretty easy on a clod.
