Dafni
Dafni's Avatar
11.20.2005, 04:00 AM
Still awake? :)
Probably it wasn't just the electro lingo, but also my harsh dialect;)
The items you mentioned (slipper) are correct, but for a Feigao motor, you would need the 5mm bore pinions.
The loss of the 4 mounting holes if you go GMaxx single speed is also a concern to me. If you want, you can ask mike if he can get you just the coupler. Then you could keep both halfes, but you would need some kind of spacer for the output shaft.
I don't know exactly about the BEC. Most of us disable it anyway, and use Koolflights UBEC. I would advise you to get one as well.
For the other boys: If Brian is only looking for 25mph-ish, how about a 9XL on 12 cells?? Should give nice runtimes.
