FLM AX10 Rebuild...
FLM AX10 Rebuild... - 12.06.2008, 11:02 PM
My own crawler build from a spec AX10...
AX-10 +
- FLM chassis
- Axial rear straight shaft conversion
- TCS rear 4 link top plate
- Axial Front battery mount plate
- STRC Front end
- Inboard links - stripped
- Losi crawler shocks
- HS 7955TG / CC BEC 6.2v
- MM / Revolver 1000KV OutRunner
- Split 3s 2p 2200mah A123 - Custom - Build from 3 B&D VX batteries - $38...
- Mayhem 7's 6Oz lead@front / 4Oz @rear
- Proline FlatIrons (Thanks Shaun) with memory foams
...Lots of bits to put back together - Shocks build with 80w
...Front end almost complete
...Motor all remounted
...Front and back end complete
12.06.2008, 11:04 PM
Winning... Most of it back together
12.06.2008, 11:06 PM
Done...
Outrunner and MM in place
Everything else done...
RCShocker
RC Monster
12.07.2008, 01:00 AM
That turned out very nice.
Snowman 78
5,280 feet above sea level
Snowman 78's Avatar
12.08.2008, 01:14 AM
Looks great!!
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
12.08.2008, 07:21 AM
More to come - just purchased a dig setup so hope to have that in for next weekend...
TDC57
TDC57's Avatar
12.09.2008, 01:56 AM
Two words come to mind!..
BAD ASS!.&. Like it!..
Looking forward to future updates and the possibility a video or two
Nothing!.. Hahahahaaa..
12.09.2008, 07:10 AM
As requested - I make a brief segment at 3.20 mark...
http://de.youtube.com/watch?v=P7ZzEQmdCU4
Will be back with a dig hopefully this weekend...
jnev
jnev's Avatar
12.09.2008, 10:23 PM
Very nice crawler. Simple yet effective. Looking forward to hearing (and seeing ) how the dig works. What radio system do you plan to use with it? How many channels are required for dig?
TDC57
TDC57's Avatar
12.09.2008, 10:30 PM
ALL RITE!! that things moves along GREAT!!
is that your back yard???
Nice video!..
Thank you for posting..
saydee1800
12.09.2008, 11:59 PM
hey
I would love to build a FLM Crawler
can you give me a list of what I need
Thanks
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
E-Revo 4s 8000Novak HV 6.5
E-Maxx 4s 6000Novak HV 6.5
Speed-T 3s 5000
For Bashers, By Bashers - http://www.BigSquidRC.com
12.16.2008, 11:50 PM
Bugger! Stripped the whole thing to replace diff lockers - add a set of traxxas steel drive outputs and install a dig....
Yeah get is all back to together and get the annoying CC bec bind issue - fix than and poof.... My HS 225 servo for the dig starts smoking... I hadn't even connected the arm...
Anyone else had one go like that?
12.21.2008, 10:23 PM
All back together again with custom chromium steel hardened lockers and a HR Dig - Which seems to works great with the full size servo!
It is a bit dwarfed by its big brother though! LOL!
12.21.2008, 10:49 PM
Nice rigs you got there!
12.22.2008, 01:37 AM
Looks good Chris. Not sure but the front steering link looks a bit low... Maybe you need a set of clockable c hubs to increase the caster towards neg. Or just move the lower links forward on the chassis one hole to bring the pinion down and rotate the steering up a bit. May help with your approach angle. Or get the ckrc behind the axle steering kit, less than 20 bucks...
I do like the axial axles, I have them on the jkeeper truck I made. I run a lower pinion angle, so my steering is not really in the way. My ground clearance looks to be less than yours, so my driveshafts are almost level. They never bind, no matter what.
