speedy
11.10.2008, 01:41 PM
i whan't to use an outrunner becasue thet are very cheap (65$ for a .200 size outrunner ) Compared to a lennher or neu for about 500-900$ :)
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
When in doubt, 1527. Oh and your link doesn't work because you have an extra "http" at the beginning. That motor should do OK though. They say 8s LiPo max so I'd be careful if you expect to run it on 10s.
stum
11.10.2008, 01:48 PM
Differential Ratio: 1
Transmission Ratio: 8.382
Other Ratio: 1
Spur Tooth Count: 57
Pinion Tooth Count: 26
Total Voltage: 22.2
Motor KV: 1577
Tire Diameter (inches): 6.88
Tire Ballooning (inches): .5
Motor Current Draw: 80
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.19 : 1
Total Ratio: 18.37592 : 1
Tire Circumference (inches): 24.76 inches (628.8 mm)
Total Motor Speed: 34000.12 RPM
Vehicle Speed: 43.38 mph (69.68 km/h)
Estimated Adjusted Speed: 41 mph (66 km/h) - 6% loss
Effective KV Value: 1531.54
KT constant: 0.86 oz-in/A
Motor Torque: 0.36 ft-lbs
Final Torque: 6.57 ft-lbs
Final Power: 1776 watts (2.4 HP)
Other Ratio: 1
Pinion Tooth Count: 20
Total Voltage: 29.6
Motor KV: 1577
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.85 : 1
Total Ratio: 23.8887 : 1
Total Motor Speed: 45669.92 RPM
Vehicle Speed: 44.82 mph (71.99 km/h)
Estimated Adjusted Speed: 42 mph (68 km/h) - 6% loss
Effective KV Value: 1542.9
Final Torque: 8.54 ft-lbs
Final Power: 2368 watts (3.2 HP)
Other Ratio: 1
Total Voltage: 22.2
Motor KV: 1500
Motor coil Ω: 0
Total Motor Speed: 33300 RPM
Vehicle Speed: 42.48 mph (68.24 km/h)
Estimated Adjusted Speed: 40 mph (64 km/h) - 6% loss
Effective KV Value: 1500
KT constant: 0.9 oz-in/A
Motor Torque: 0.38 ft-lbs
Final Torque: 6.9 ft-lbs
Other Ratio: 1
Pinion Tooth Count: 25
Total Voltage: 29.6
Motor KV: 1250
Motor coil Ω: 0
Spur/Pinion Ratio: 2.28 : 1
Total Ratio: 19.11096 : 1
Total Motor Speed: 37000 RPM
Vehicle Speed: 45.39 mph (72.91 km/h)
Estimated Adjusted Speed: 43 mph (69 km/h) - 6% loss
Effective KV Value: 1250
KT constant: 1.08 oz-in/A
Motor Torque: 0.45 ft-lbs
Final Torque: 8.62 ft-lbs
What's_nitro?
11.10.2008, 01:51 PM
I'd definitely go 8s with the 1521/1y. Lots more torque at the wheels with that gearing. Speedy, those motors are nice and they will get the job done, but they are $65 for a reason. If they get pushed too hard they pop, fizz, etc. You should save your money and get better stuff because you'll be happier in the end. On the other hand, try the outrunner. If it blows up then w/e- it was cheap!
mohanjude
Need for speed
mohanjude's Avatar
11.10.2008, 01:52 PM
I can safely say that a 1521 will not be too happy trying to move a 20+ lb vehicle at 40+ mph.
Pimp
I second that. I tried the 1521 and it struggled to push my 22lb 2WD car. I think the 1527 will be ok. I have a Lehner 2280 and it shifted the FG brushless car ok. The Lehner 2250 which is the same size as the 1521 Neu had to work hard. As the Lehner 2280 is the same size as the Neu 1527 and the 1527 is muti pole motor it should have the torque to propel the car from standstill and still be geared for 50mph on 10S
Mohan
speedy
11.10.2008, 01:57 PM
woud a kb45 xl motor make it ?i'd like the same preformance like the baja has with the stock 26cc engine !
Hobbycity sell a 100A hv esc for up to 12s lipo for like 120$ do you guy's think it woud work ?
What's_nitro?
11.10.2008, 02:04 PM
I don't think the KB45 would be enough if some are saying that the 1521 wouldn't cut it. The Sentilon HV controllers are very nice though. That would be my choice for an "inexpensive" controller. You might want to consider the CC HV110 as well.
11.10.2008, 02:42 PM
Originally Posted by mohanjude View Post
Pimp
Mohan
My point exactly! You need a motor with plenty of torque to get a heavy vehicle rolling. A smaller motor geared down may do it, but will not be optimum.
Oppressor
11.10.2008, 03:39 PM
you can't compare motors based on bhp ! i meen a .21 nitro engine can put out about 3bhp but they don't have the tq of an scooter 3bhp engine !
Peoples tried to rationalize why electric motors were so overwhelming in comparison to an nitro engine. The truth is that hp is still 750 watts no matter how you look and that torque should affect acceleration but for top speed that main culprit should be real hp and gearing.
The reason you can't it's because nitro engine in reality don't reach anywhere near the claimed hp. A 4 hp motors might in reality put 1.7-1.8 hp on a dyno!
Once you will have paid for a controller able to run realibly your motors and the batts, 500$ motors won't look so expansive.
The issue here is not having enough power or not as even an Feigao XL could push around a Baja5b around at 40-45 mph.
The issue is : "Will it cook doing it?"
Yes, a Kb45 will be able to push around a Baja 5b at 40+ mph but not for long(Read less than a run).
You are trying to push something that is twice as heavy as a e-maxx so i figure that a motor twice as massive than a neu 1515, lehner 1950, hacker b50/c50 or plettenberg big maxximum should do.
I would look at:
Neu 1527 or 2215
Lehner 2280 (2250 a bit on the tight side)
Hacker A60-L
Plettenberg Bolido
Also once you will have paid the battery and the controller to push around a Baja 5b, 300 to 500$ for an high-end brushless motors will look trivial.
For the neu 1521, i believe that it might work but it won't let you enough head room. Meaning you might be able to run on a cool day and cook it on another...
600+ grams brushless motors is a good beginnings for a 1/5 scale. High end brushless motors can sustain about double the power of cheaper one without cooking because they generate half as much heat by hp as they are twice as much efficients(90% vs 80% [Yes 10% is a world of diffrence!].
For the controller, it handle about as much power than a MMM (12s 100 amps is as much power than a 6s 200 amps controller).
Beside it's probably a "cheap" brand so i don't think that it would cut it.
1/5 conversion and cheap don't go hand in hand. Hell it's hard even for an 1/8...
What's_nitro?
11.10.2008, 11:25 PM
Oppressor, the Sentilon line of controllers are probably better quality than everything else on the Hobby City site. I have used one of those 100A controllers and it was great! As long as the truck is reasonably geared there will be no issues with cogging. They have a large heatsink as well, but mine never got much above ambient. I was using it in my Ofna GTP on 6s with a Neu 1515/1y geared for about 76mph (using mechanical brakes of course). I could light up all 4 tires (foams) at will.
Oppressor
11.11.2008, 07:06 PM
That's good but it doesn't change the fact that 12s and 100 amp seem too little to me for an 1/5 and 40+ mph...
What's_nitro?
11.11.2008, 07:36 PM
Well, then I guess an HV110 is in order. But I don't think he wants to spend that much....
SpeedAssault
SpeedAssault's Avatar
12.08.2008, 01:32 AM
I liked reading this info but was a little tough to follow.
I'm just trying to learn about high power brushless for a 1/5 build I'm starting at the bottom low budget at till I can afford it
Thank you for this subject
Keep us informed and the outcome
Ryu James
Ryu James's Avatar
12.08.2008, 04:00 AM
I would look at:
Neu 1527 or 2215
Hacker A60-L
Plettenberg Bolido
OPpressor has nailed it on the head. 1/5 conversion and "budget" do not really go hand in hand. If you want to do the conversion right and actually SAVE yourself a lot of time and money then do it right the first time and use quality parts all the way around. That means something like the Neu 2215 or a Bolido and a MGM esc and ThunderPower Lipos. Those 3 items will put you in the $1500-$1800 range combined. Or you can cut corners and spend $500 and then have to come back and spend the $1800 anyway in a months time. Just my humble opinion. Plus, if you do it right you will be way pleased. Save up and buy one part at a time or something. Then build the baddest Baja anyone has seen.
Jammin SCRT10 Neu 1512 1y
12.08.2008, 11:28 AM
I agree. Better to do it right the first time than to do it twice.
A smaller motor can push it, but as others say, it will get too hot too fast. For something that large, you need torque - and that requires a large motor. I too would look at the 1527 at a minimum, but the 2215 probably would be more optimum.
Once you get your motor choice squared away, use high voltage to keep current levels manageable. Even on 10s, I would expect large current spikes on startup simply because of the size/weight. For something like this, I would like a 200A ESC @ 10s (or 12s), otherwise the ESC will be working hard IMO. I don't think the Sentilon will like this setup unless you can have someone parallel 2 or 3 of the FET boards, but then you are at ~$300. At that point, might as well get an MGM or something. Contact Castle - they might have a recommendation for you (they have a large HV/200A ESC in their special projects page). They may be able to custom build you a super-HV110 by adding one or two more FET PCBs, but that will cost more.
No matter what, pushing a 25lb vehicle to 40mph speeds is not gonna be cheap.
