MetalMan
MetalMan's Avatar
11.21.2005, 09:00 PM
Originally posted by squeeforever
you can use a bk with the pletty. on the warriors with the 100,000 rpm limit it just can exceed 50,000. i think the micros have a 150,000 rpm limit (please correct me if im wrong) so if would be good up to 75,000 rpms which you would never see with that motor. im not sure what would happen if it did exceed the max though.
-corey
I have heard that the BK Warrior controllers aren't really able to run the 4-pole Plettys very well, but this doesn't have anything to do with RPM limits (which I believe you are correct on).
The MicroCar is the one with the 42,000 RPM limit.
