Metallover
RC-Monster Spudgunner
Metallover's Avatar
12.21.2008, 06:38 PM
1. Always have a spare battery for just testing things and fooling around. I use a 4AA rx pack with the plastic part of the JST plug taken off. The JST plug can easily go back on.
2. Gell cell or lead acid batteries are great for charging batteries away from power. Your charger can probably hook up to them with alligator clips. I have two from an old electric scooter. These batteries have tons of uses.
3. chairs or stools are good for sitting on, but also make a good PVC dremeling location.
ID:	6098   Click image for larger version
ID:	6099   Click image for larger version
12.21.2008, 07:01 PM
A small addition to the shoe goo on the body idea. Use some aluminum duct tape (most hardware stores will have this) around the body post locations under the body. This will stop the posts or body clips under the body from rubbing the paint off. Plus you can use this anywhere else anything touches the body. Can also be used as a heat sheild for the tuned pipe (not that anyone here runs nitro) It is like 5-8 bucks a roll and will last forever for our uses. Also makes good headlight buckets for leds. Many other uses too.
