lutach
lutach's Avatar
12.22.2008, 05:04 PM
thats hard to believe...
With 6S 2200 and 2500mAh it's actually close to 7lbs and with 8S 3700mAh it's actually a little over 7.5lbs.
lutach
lutach's Avatar
12.22.2008, 05:05 PM
I hope you will send mine if you use my design . I'm very picky too , it must be perfect .
12.22.2008, 05:08 PM
how well does it work? where can i buy one? any pics? how much did u pay? i would love to stop using my dremel for milling. lol.
This is the mill I am getting tomorrow.
http://www.harborfreight.com/cpi/cta...emnumber=33686
Oh ok.
I'm actually not going to use your design, just going with a single battery pack. Only chassis I can compare it to would be Mike's, except mine will be CF and I will have the RX in a different spot.
Ryu James
Ryu James's Avatar
12.22.2008, 07:01 PM
it looks pretty nice but is there a way to move the item you are milling or do you just have to use your hands? if there is a way to clamp down the chassis and then move the entire table in any direction (by turning knobs or something like on a lathe) this will result in much straighter cuts. i know moving it around by hand to mill out an area is tough to keep straight. i will say this though. milling carbon fiber is 100x easier than milling alum. you can see the milling i did on my CF chassis with just my dremel. not super clean but not bad. i tried the same thing on alum and just gave up. a real pain in the ass with a dremel.
chassisfusion1
Jammin SCRT10 Neu 1512 1y
lutach
lutach's Avatar
12.22.2008, 07:04 PM
Most manual milling machines you can lock one lever and move the direction you want without the other moving. Machines that cnc's CF are very high RPM and uses carbide bits and this is where the high cost comes into play.
12.22.2008, 07:18 PM
The mill has a sliding table that is controlled by turning knobs. Lutach, do you think the mill I linked to is up to the task of milling CF?
lutach
lutach's Avatar
12.22.2008, 07:32 PM
Yes, those knobs actually lock to avoid it from sliding and messing up your job (The ones I've seen does that lol). The thing with CF is that the machines that CNCs it are very high RPM and the bits themselfs are somewhat expensive. This is information from some of my clients.
