FastXR
12.22.2008, 05:30 PM
Thomas, I think we (or at least I) would like a more technical explanation about how timing, punch control, and start power settings work.
For example, when I mash the throttle at a stop, the transmitter goes from neutral (~1.5ms) to WOT (~2ms) in a blink. However, how does the ESC respond to that, and what do those settings do internally to the ESC to affect that?
I see it like this:
Timing: Is this kinda like advancing the timing on a 1:1 car; where the motor signal pulses are more or less "ahead" of the rotor position to get it to spin faster?
Punch control: Does this take the instantaneous change in throttle input and ramp it up over a longer time instead, kind of like an integrator in an op-amp? So, even though the trottle goes from neutral to WOT in 1ms, the ESC ramps that up over say 50ms.
Start power: I really have no idea here. Is this some sort of current limiter? Or does the ESC send larger PWM pulses to the motor to get it running?
Great questions, I would like to know the answers to these as well!
Thomas Porfert
Thomas Porfert's Avatar
Post 12.22.2008, 05:48 PM
Please see Patrick's reply 2 posts down, he breaks down every setting in easy to understand wording. He's a master at taking complex ideas and explaining them in a simple and comprehensive way. Learned more from him about electronics than any book I've ever read!
