Go Back   RC-Monster Forums > Support Forums > Novak
e-rev project
12.22.2008, 09:46 PM
ok problem was 2 flipped diffs.... so are hv 6.5 esc directional? it only wanted forward to be one specific way; i thought you could easily flip it with the channel but that did nothing good the truck would always move if i flipped the chanel after the program
rommel
12.28.2008, 03:28 AM
if you have flipped the diffs in wrong direction that causes ur prob...or maybe u have program ur esc in wrong setting... first thing is connect batt on esc make sure its off then press the black button on ur esc then switch it on, at this state motor wont run then pull the tx trigger you can see the led blinks then push the trigger and ur esc is good after that unplugged the esc wire on to the rx then press again the button in ur esc u will see that every led lits up as soon as all led lights up press again the esc button twice then u will see all led blinks twice now ur on profile #2 w/c is 50% forward and 50% reverse then ur good to go hope this helps...
