TexasSP
Something, anything, nothing
TexasSP's Avatar
12.23.2008, 11:17 AM
Except for that guy lincpimp, everything over here is overkill in overdrive.
lincpimp is the epitome of conservative setups with many underpowered and slow little rigs.........
www.cubicle101.com
12.23.2008, 11:19 AM
Originally Posted by TexasSP View Post
...lincpimp is the epitome of conservative setups with many underpowered and slow little rigs.........
Probably spends less on repair bills too!
12.23.2008, 11:29 AM
Ahhh, the truth comes out....
Funny you should say that... I used to spend quite a bit when I first got in to rc, but I guess my driving skill has improved and I stopped hiting stuff. I have never really had ultra-heavy trucks so they generally hold up fine with stock parts. My bash area is usually free of cars and trees, and I make sure my tires are glued and everything is bolted together right, which is often the cause of breakage. I did stick a tire or a truck really good yesterday while testing the lst2, but it is a solid truck and I hit the tire pretty square. Had to dodge a moving car, and the tires were sliding in some gravel. Plus that truck is only doing about 37mph, waiting on some larger pinions.!
12.23.2008, 11:37 AM
...and I stopped hiting stuff....
So, that's your secret! I gotta try that.
TexasSP
TexasSP's Avatar
12.23.2008, 01:12 PM
Funny how when you stop hitting immovable objects things stop breaking.....
I hardly mess up anything anymore either. I just try to avoid cluttered areas to run in. I am managing a construction project building an Airplane Hangar/Office right now and got to run inside the hangar portion which is 9500 square feet. That was a blast drifting around on the smooth cement.......
No worries about hitting anything in that space!
www.cubicle101.com
