BL Dreamer
12.24.2008, 01:36 PM
take lots of build pics for this noob.
Ryu James
Ryu James's Avatar
12.24.2008, 02:40 PM
already was planning on it. i will post them all when finished.
Jammin SCRT10 Neu 1512 1y
Ryu James
Ryu James's Avatar
12.26.2008, 06:51 PM
here is the build pics of version 4 as promised. still needs some adjusment though. because the center diff sits so high off the chassis with the RCM conversion i had to use 3 shims on the servo stands and 1/8" of spacers on the servo arm and the servo still doesnt sit high enough. so i am going to somehow try to make the setup work without the huge center diff shim.
i also had to use a Tekno long shank pinion after making the spacer so that the motor can didnt rub the brakes. anyway, the pics tell the story for the most part.
i also move the esc behind the battery. looks much cleaner.
v4.15
v4.14
2 pices of 3mm carbon glued together for a 6mm piece. just enough to clear the brakes now. one side had to be ground down to clear the brakes. 2 screws hold the piece against the motor and the other two screws hold themotor to the mount.
v4.13
v4.11
v4.9
v4.8
v4.7
v4.6
Ryu James
Ryu James's Avatar
12.26.2008, 06:55 PM
a couple more pics. the things seems to drive great now. havent been able to test on track yet but will soon. love the mech brakes finally.
v4.4
pic of the shims and nut used for spacer on servo arm
v4.3
v4.2
v4.1
