Hyperion dimensions.
FG101C
Hyperion dimensions. -
12.27.2008, 02:40 PM
http://www.rc-monster.com/proddetail...d=HP-LVX43505S
Anybody have the dimensions of the pack linked?
Thanks.
FG101C
Find all posts by FG101C
2
jnev
12.27.2008, 09:15 PM
47mm x 160mm x 39mm
jnev
Find all posts by jnev
3
FG101C
12.27.2008, 09:56 PM
Thank you. Noticed you have a D8, does it fit under the body in Mike's battery tray?
FG101C
4
jnev
12.27.2008, 11:14 PM
I actually am in the process of building the D8 at the moment, so I can't answer that quite yet.
jnev
5
FG101C
12.28.2008, 05:43 AM
Ok, thanks again. I'm just wondering if the 4350mah 5s would give me the same run time as the 6000mah 4s if I gear down two teeth on the pinion.
The 15 tooth on 4s is good, but could use just a little more top end and a slightly cooler temp.
FG101C
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
