E-fanatic
Brushless only!
E-fanatic's Avatar
12.30.2008, 06:27 PM
1: try a heat gun on the cover and push it out a little. mine rubbed a little too. Heated it up and noe its good.
2: great to hear that you runtimes are that good!!!
3: His calc gives a great estimate. Its been really close on every thing but the lst.
4: just be careful b/c the case can open up on you
5: geared correctly the castle motor runs really cool on 6s. Looks though you found the sweet spot!
6:The spark is from the power capacitors chargeing. Its normal and ok
7:it slows the truck down alot.
8: you wont notice any decrease in you power using a good lipo until they are dead! they dump quick. If your battery lasts 40 mins max you will have near the same power at 1 min into it as the 39th min.
9: only charging to 50%(store mode) is only if you are not going to play in the next two week. If you are going to play again in the next two weeks fill the battery up!
HOPE THIS HELPS!
