Semi Pro
Semi Pro's Avatar
12.31.2008, 09:03 PM
savage diffs are the same as hotbodies and ofna
12.31.2008, 09:25 PM
I will say that the HB hardened internals will NOT fit a losi lst diff. They should fit any kyosh, ofna HB (of course) diff out there, including the crt diffs.
Savage diffs are slightly different in length, so you may need to shim other mfg internals to fit...
riverat1540
riverat1540's Avatar
01.01.2009, 02:40 AM
right on good to know found a hardened lsp center diff for cheap so just swapped it out and i blew the front so will also be changing that out as well
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
