RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
06.10.2005, 06:30 PM
Enjoy!
crjackson
06.11.2005, 08:01 PM
Originally posted by MadDog
Here is a picture of it before i sent it back. As you can see the esc fits right under the motor.
MadDog, can you show me a picture of how you have your transmission servo/linkage mounted? I just got finished mounting mine the way the Gorilla instruction sheet shows and I'm not really happy with the fit. I nearly distroyed the tranny detent trying to get the linkage in the way it says. I was trying to bend the shift linkage like the instructions stated and ended up bending the tranny detent a little at the linkage hole while trying to bend it back after inserting it (it kept falling out so I was putting the bend back in).
It looks like your method is much less work and a better fit too...
reciever pack
barndog
reciever pack - 06.20.2005, 01:23 AM
hello i was wondering if i run a reciever pack do i unplug the black jumper under controller or not.i am very new to bl.i have a 9l 9918 set up.
Serum
Serum's Avatar
06.20.2005, 02:11 AM
Yes, you need to unplug the BEC jumper. (however i heard people running both, but i have seen brushed controllers going up in smoke by using both..)
RC-Monster Mike
Site Owner
06.20.2005, 05:54 AM
It is ok to run both on low cell counts(8 or less), but for 12+ cell operation it is better to unplug the black jumper when using an external BEC or receiver pack.
thanks
barndog
thanks - 06.20.2005, 09:00 AM
thanks guys for the fast response.
squeeforever
squeeforever's Avatar
06.21.2005, 07:40 PM
so if your running a reciever pack you take the big black jumper off and leave it off? what about the little black one?
black jumper
barndog
black jumper - 06.21.2005, 08:28 PM
what if you unplug the red wire from the reciever plug.
RC-Monster Mike
Site Owner
06.21.2005, 08:40 PM
Leave the jumper that isn't covered in the heat shrink(programming jumper). The controller won't work without it.
Re: black jumper
RC-Monster Mike
Site Owner
Re: black jumper - 06.21.2005, 08:41 PM
That is how you would do it if the black jumper wasn't there to pull out. It is easier to pull the jumper(and put it back if you need the BEC) than it is to mess with the rec. lead (and once you pull it from here, the wire will never stay in as well again).
squeeforever
06.21.2005, 11:39 PM
what about the little black one under the big one. about an eight inch think.there is one on both the orange and black jumpers.
Serum
Serum's Avatar
06.22.2005, 03:18 AM
That is not a jumper, that is the plastic that hold the two pins toghether for the jumpers.
look here..
