shaunjohnson
i pwn nitro
shaunjohnson's Avatar
01.07.2009, 04:09 AM
thanks for all the help
some good batteries running around here
i want to keep cheap so i came up with a good idea... tell me if this is ok...
i currently own a 8000mah trueRC 10c 3s lipo.
that is being run in the rustler...
what if i just got another one...
that'll give me 6s 8000mah 10c.
they are "rated" for 120A burst but i think he under rates them slightly..anyway...
some snooping around this forum tells me my revo will require bursts/peaks of up to 2400 watts of power.
so on 4s that's 160A's...too much
BUT on 6s that's only 120A's...that's within my burst range
so should/could i run 2 x trueRC 3s 8000mah 10c lipo's???
(yeah that's about one KG of batts there ..is that ok as long as i fiddle with the suspension to carry that weight?)
shaun
sikeston34m
sikeston34m's Avatar
01.07.2009, 08:13 AM
shaun
2 Lipo Packs ran in a series should be the same age. A Brand new one ran with a used one will tend to over discharge the older one.
Double check me on this, but I really don't believe the 3S 8000mah packs will fit the compartments.
About the highest 6S capacity setup I've been able to fit is 5000mah.
shaunjohnson
i pwn nitro
01.07.2009, 09:26 AM
ok understood.
the pack isnt "old" so to speak, only has maby 10 cycles on it.
if i cycle and charge it again and bring it back to health do you think it will be ok?
and i'm doing a rEvo conversion, so there are not any battery compartments to worry about
