Krawlin
Got brushless?
Krawlin's Avatar
01.08.2009, 11:05 PM
Bye bye MM... You need a stepped up ESC now.
Hey, don't be pickin' on my MM. If it lasts 10 runs I will be happy and it will prove that it is one hell of an ESC.
Monster GT Conversion
Krawlin
Got brushless?
Krawlin's Avatar
01.09.2009, 09:49 PM
Alright so I got everything installed and did a first run tonight.
There was 1 bug, otherwise it was amazing. After long bursts of full throttle, and sometimes after wheelies and such, and after long bursts of full throttle, when I would let off and it would coast, or even on take off, the ESC would turn off, and then turn back on again and go through its whole arming tone stuff. And I didn't even run use my extra capacitor board and the ESC was only warm to the touch and the motor was slightly warmer and the LiPo's seemed to be just above room temp. (They are 30C constant and 60C burst, two 2S 4000mAh, in series for 4S.)
It could be a loose connection, the on/off switch, or I am pulling too many amps through the ESC. I also have my cutoff set at 13.8volts (I know, I am paranoid), and my theory was that maybe the battery was dipping below cutoff voltage cause the ESC to shut off and then when the voltage recovered the ESC came back on. Not exactly sure what it is though. Does the MM have an overamp cutoff? Maybe my BEC is drawing too much, should I lower the voltage to like 5.5 volts on the BEC?
What do you guys think? I am going to eliminate my on/off switch, I checked the receiver plug to see if it was messed up or loose, and it was fine.
But other than that annoying problem, THIS THING IS A TOTAL BEAST!!! It has some crazy power, will wheelie (if it can get traction) at 3/4 throttle. Haven't tried it on pavement yet but I dont have much doubt that this thing could do a standing backflip on pavement. Its tons of fun and more speed and power than I expected!
Krawlin
Got brushless?
Krawlin's Avatar
01.10.2009, 01:59 AM
I think it might be time for an MMM. Seems my MM has given up the ghost. When I plug the battery in and it turns on, it turns right back off, then on and does the tone, and it does that over and over and over and over. And I probably need an MMM anyway due to the size of the motor and the amps it pulls.
I have a used XXX-T with a bunch of upgrades that I can trade for a new MMM if anyone is interested BTW.
Quattro 83
01.10.2009, 12:31 PM
Glad your enjoying your Emaxx, BUT had to comment on your inflammatory title "my emaxx kicks your emaxx's butt" I'm with SuicideNeil on this one!
Have you seen some of the members Emaxxes here? There are some seriously clued up individuals on this site, with seriously bling cars, and have been for years and years.
Seriously, unless your running full UE and Gmaxx parts with some mind blowing home made additions like centre diff etc, etc, you just can't say that, and even if you could, you just shouldn't!
For the record here's my 2 year old Emaxx conversion which I'd rate as very ordinary, and truth be told hardly gets used as my brushless Truggies and Buggies are more fun to drive.
George16
Supermaxx
George16's Avatar
01.10.2009, 08:27 PM
Dude, the guy was just kidding!!! He just did it for fun .
Anyway, both of you have nice emaxxes but mine still looks better .
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Krawlin
Got brushless?
Krawlin's Avatar
01.10.2009, 11:02 PM
Uploading a video now of the 2nd run. It still shuts itself off and on. I will post the link once its done uploading.
Krawlin
Got brushless?
Krawlin's Avatar
01.10.2009, 11:15 PM
Alright, here is a video of what this thing does.
http://s291.photobucket.com/albums/l...t=DSCN2045.flv
01.10.2009, 11:21 PM
sounds a lot like bad connectors between the esc and battery.
The problems make me think they are dean's connectors. Correct?
Although they may look good connectors go bad from the slight arc of connecting and disconnecting.
I had the same problem, new connectors solved it.
please try and report results(I'd like to know if I diagnosed it correctly, I learn from my mistakes!)
Tags
kick ass maxx
