Xtreme R/C
11.26.2005, 11:30 AM
Do you think if I went with the wanderer "S" in a lower turn, like 10-15 an geared it for a top speed of 2-3 mph, I wouldn't need the torque of the XL?
I'm hoping that with the ultra low gearing, cogging won't be a problem, although most of the driving in crawling is done with the throttle bearly cracked.
A lower turn motor would be better to give me a broader rpm range to work with.
Where can I find the specs on the wanderers, Mike shows 6-12 turn. What turns do they come in?
The other option I'm keeping open is puting a High/Low range in the tranny. So I can quickly move around and position the truck then shift into granny low to crawl.
What's the least inexpensive controller I can get away with running?
