watercooling
transtalon
watercooling - 01.09.2009, 11:31 PM
My extended Lst2 was running a 34/63 gears, stock is 25/63. It's just too much load from excessive gear that is why I fried two ESC. Now I know how to be conservative as I spent way too much on ESC. I made a flat chassis 2" extended Lst2, I'll be putting the 1527 1D or 80mm 2K Medusa(when it arrives).I'll be running a OFNA spider 53 spur 13? It should be weigh 14lbs hopefully or lower. I'm sure this would handle better with the lower
center of gravity.
