Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Janezki
Avid Gear Crusher
Janezki's Avatar
01.11.2009, 04:58 AM
Use the calculator at ledcalc.com and input all the necessary values, then click "Click To Calculate" button. The program tells you the proper resistor value in your case (in Ohms) and draws you the proper wiring picture.
The size of the resistor is depending from system voltage and leds used.
doo540
01.13.2009, 09:44 AM
Janezki
I exploded my 3 speed last week too. (I had about 6 lipo packs on it) I also have a Kershaw Design direct drive on order. I'm also going to work on using a Ofna diff out of there dirt oval car (solid spool drive) with the motor driving that, like a truggy setup.
For answers on the Cen Gen diff mod follow this link
http://www.rcbasher.com/savcendiffs.html
I used the four pinion setup with 7000 oil in front and 5000 in the rear diffs.
I need more time to tell if these are the right weight.
I'm running a Neu 1515 1y on 4s 8400 lipo, with MMMv2 and 16 tooth pinion and stock spur/slipper full tight. That was good for 49 mph before the rear end change. The Cen Gen rear end will give you higher top end. Iplan on switching to Flight Power 6s 5000 lipo at some point this up coming summer.
Lights look really cool on your truck, how do you keep your truck body so nice looking, mine is trashed......
Janezki
Avid Gear Crusher
Janezki's Avatar
01.13.2009, 11:29 AM
Thanks for the link, doo540. Much appreciated!
Those CEN diffs do look mean.
I have no hurry in replacing the diffs yet, I'll wait until ppl have experiences from the Flux diffs and then have to compare which comes cheaper.
Also, the Kershaw tranny raises total gearing ratio, so with CEN diffs it gets even more taller - might be time to get lower kv motor.
Which I'm in need anyway atm - went for a little drive with friends on Sunday, but my Savage just didn't want to move - stuttering starts, not possible to give more than half throttle or esc cuts all power. I tried the motor without a load and MGM gave more throttle instead of braking, which had never happened before with this motor. We tried the motor in my friends' truck too and had the same results, so it's not MGM but Feigao which is toasted now...
Anyway, I ordered two of those KD36-74-15XL 1100kv motors from HobbyCity. They're a bit on the low side on kv, but hopefully I'll get over the wintertime with them. Together with 6S & Kershaw transmission they'll prolly be just fine and motor temps should be atleast tolerable.
Here's few pics with my friends' brushless trucks, eRevo & Hobao Hyper ST:
Oh, doo540 - You can find the secret for my well survived Savage body when you look at the ground at those pics.
