01.11.2009, 12:14 PM
Mozzy seems to have the real world answer. Of course, theoretically regenerative motor braking would be more efficient. But with an r/c, on a track, how often do we brake and coast to a stop? Never. We're either stabbing the brakes or locking up the wheels, which of course wouldn't regain any power. More a/b comparisons like Mozzy did will confirm that mech brakes are the more efficient setup. Very interesting. One more reason to always keep an open mind and always keep learning. Thanks Mozzy!
Ryu James
Ryu James's Avatar
01.11.2009, 01:33 PM
i totally agree with you paralyzed. the proof is in the pudding and Mozzy is the one who has brought some to the table.
@George
i agree with you about the elektri-clutch setup. I dont like it. i definitely prefer direct-drive. i dont know, i was going to pull out a clutch again this week and try it again since i am a better driver now. the Tekno guys still religously use the clutch setup. but Danny recently told me that one of their biggest sellers recently are the long shank pinions. that would be a good user name - Longshanks. lol. anyway, when i switched from cluthc to direct drive i was expecting some huge difference but i didnt notice much. other than the pinion is sooooo much quieter. i can still control at low speeds. not quite like a clutch i guess but i have never felt i need to switch.
mozzy, thanks for sharing more info. so it sounds like on motor breaks your run times were always roughly the same amount of run time. so the mech brakes 4 extra mins was after several times with motor breaks, right?
Jammin SCRT10 Neu 1512 1y
Mozzy
Mozzy's Avatar
01.13.2009, 10:32 AM
@George
I'd driven the CRT with motor brakes alot prior to going the mech route. Was also trying different gear ratios to see what was best & then settled on my current set up.
This set up was used with both motor & mech brakes & the mech brakes yielded a longer runtime by over 4mins.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
