lipo management ??
CRTIM
lipo management ?? - 01.13.2009, 01:01 AM
being very new to the lipo scene(5s 5000mah),and not being able to run my lipo's as much as i'd like ,would having a gadget like this benefit in helping me manage my battery's life between running???
http://www.hobbycity.com/hobbycity/s...idProduct=6748
I'm kinda in the dark about proper lipo storage(sometimes 2 or 3 months) i know my Hyperion 0610 doesnt discharge but i also have the Hyperion 5i with discharge(1a max discharge rate)could i use that for discharging and getting battery ready for storage ??....i hope I'm making some sorts of sense ...LOL...
thanks for any advice or help on these noob questions
eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
01.13.2009, 01:18 AM
as far as i have heard... you want to check to see that your cells are balanced often... if you aren't running it for a while, I would at least check once or twice a week... if you see that one a cell starts to drop lower and quicker than the others, it may be the sign of a pack going bad, and you wouldnt want it to take down your other cells... your hyperion chargers should have a discharge and storage discharge mode, so that should be pretty clear cut. I have heard that you do not need to discharge your lipo for long periods of time if you keep it in a place where the temperature barely/rarely changes, like a closet or some place indoors. other things that could help extend your life is to keep your lipo from being damaged. building/buying a protective battery tray, using some soft foam inserts, etc. while running will keep your lipo away from most damage. hard-cased lipos are great in the sence that they have more protection than just heatshrink. also, check Brian's speed calculator, and check your gearing. depending on the discharge rating of your lipo(C rating), it could be very easy to be pulling wayy more amperage than your lipo allows for. if overgearing doesn't kill your lipo, it certainly will shorten it's lifespan. hope this helps
Also, i havent tried any seperate balancers(i always balance while charging) but i heard the astro blinky is really good
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
