Starting a Swift 2 brushless conversion
harryf1
Starting a Swift 2 brushless conversion - 01.13.2009, 01:42 PM
Hi, i am in the process of converting my nanda racing swift 2 1/8 buggy (don't laugh!) to brushless. What motor/esc/battery/pinion configuration would you recommend? If it helps, i would like to go at least as fast as the buggy was when it was stock nitro so around 50mph, the wheel diameter is 33cm and my buggy will weigh about 3kg when completed.
Thanks.
harryf1
01.13.2009, 03:29 PM
i will also be designing/making my own motor mount and center diff plate to match the motor/esc
dirt101
dirt101's Avatar
01.13.2009, 05:09 PM
just so you know the stock probably went around 37, but anyways I would go with the caslte neu 2200k/v combo, a zippy 5000mah 4s lipo, and for gearing you can use this
rustler, lx2e, xxt cr
harryf1
01.13.2009, 06:03 PM
ok thanks, what would you recommend as the max amount of teeth i could get away with on the pinion with the standard 46T spur without the motor overheating?
01.13.2009, 07:15 PM
Use the gearing calculator in that link- just enter your diff ratios and tire sizes etc, then find a pinion that gives you ~40mph with your 46t spur.
What heck is a Swift 2 1/8 buggy anyway- pics/ link required.
anson
01.13.2009, 07:39 PM
I want to see these 33cm diameter wheels! Did you mean circumference?
http://www.racing-cars.com/products....cnumber=15909# Is that it?
hailmick
01.14.2009, 12:44 AM
i think he means inches
and thats the buggy alright
one company makes the chassis then they are redaged by about 3 resellers
harryf1
01.14.2009, 02:59 AM
yes sorry i meant 33cm circumference and yeh it is that buggy. I've had it about 3 years. Thanks for all your replys, i'll post pics etc up of the whole build once its complete.
dirt101
dirt101's Avatar
01.14.2009, 05:02 PM
I would gear for about 38mph. My truck is geared for 42, and its just a little faster than I would like it.
that buggy looks sweet...I love the purple and carbon look.
harryf1
01.14.2009, 05:26 PM
yeh it is a very nice buggy to look at. After much deliberation i'm going to go with the 2650kv monster combo! i can't wait!
harryf1
01.18.2009, 03:33 PM
here's some pictures:
http://picasaweb.google.com/harry.bu...at=directlink#
not bad considering it's 3 years old and very well used.
