cdis
01.16.2009, 06:02 AM
What an excellent idea! I saw those, but I thought they were only for Neu motors.
I don't suppose anyone has a picture of an RCM brake spacer? I was considering something like that but didn't know Mike sells em. I'm also not sure if it would solve the issue unless its fairly wide. It may allow the front brake pad fit, but the rear one would still be stuck flush up against the side of the can. .25" = about 6mm so it might work, but as they say, a picture says 1000 words.
The 80mm medusa coming is the 1600kv one, so the larger pinion will be fine for that, just want to get something that works until whenever they eventually ship mine out.
