Rivermaxx
01.20.2009, 12:14 PM
So let me guess that novak i posted specs on wont work with a brushless setup. What brushless motor is equal to a 12 turn 550? Because I have know idea what those numbers mean. Sounds like I am going to go with the mmm combo and wait till the slipperential comes out so It can be symetrical. Thanks guys Btw will a g2 chassis work with a UE mono block?
George16
Supermaxx
George16's Avatar
01.21.2009, 05:15 AM
Only if you use the G1 rear end or cut the G2 rear end. I have a G1 rear end with mono. The driveshaft you'll need is 110mm. You can buy the titanium 110mm shafts from UE.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
