mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
01.27.2009, 01:00 AM
Originally Posted by E-vil Maxx View Post
Ok so im converting my slayer to vxl brushless I will be running a maxamps 3s lipo, I would like to know if there is a way to get rid of the mechanical brakes, and use the motor brake I also want to keep it 2 speed. Also what gearing would you suggest. I would also like to get rid of the clutch bell and run it direct with a longer pinion. Thanks
honestly, a VXL does not have enough power to push a slayer. a medusa 70mm 2000kv with a MMM on 4s-6s is the cheapest setup and has awesome temps and power, you get what you pay for. i would also not recommend purchasing maxamp as many believe they are overated and data supports this. try a couple 30c flightmax zippys http://www.hobbycity.com/hobbycity/s...1&ParentCat=85
also. do you have a conversion kit?
idk about motor brakes with two speed. but locking into 2nd is the best option. why do you want two speed?
-mikey09120
E-vil Maxx
01.27.2009, 01:06 AM
I have had real good luck with maxamps so far plus they are only 20 minutes from my house and if you pick up the lipo directly from them you get 25% off. I want to try the vxl first if it sucks I will upgrade.
