Need some setup help guys, G2R
crazyjr
crazyjr's Avatar
Need some setup help guys, G2R - 01.29.2009, 02:04 AM
I am planning to rebuild my G2R, it has had a rough life and now i plan to race it seriously. I know it needs 4 new drive shafts (one broke) and possibly a new pair of X-braces. My current setup is a Neu 1515/2.5d/f with a quark 125 and either 4 or 5s lipo's, I was never good at suspension setups but want a good solid racer. the current setup is Emaxx tranny w/gorilla half conversion, Strobe w/51 mod-1 gear and 20 pinion, RC-Monster V1 1/8 buggy diffs (I think 20,000 front and 10,000 rear) the suspension has P1 rockers w/lt springs and 70wt oil.
I just need a opening setup to work with, here are what i plan to add to it. The platnium series variable pistons and possible upgrade to v.3 Rc Monster 1/8 buggy diffs. I also am thinking of doing the New Emaxx tranny or E-revo tranny, I really want a center diff, but don't think mike is going to follow through on the slipperential. I like the Losi wheels and tires off the truggy, so i'm going to run them. Any help on setups will be greatly appriciated
George16
Supermaxx
George16's Avatar
01.29.2009, 02:21 AM
Start with P2 rockers and 50wt oil all around. Use orange and gold shock springs. 10 and 20K are too thick for 1/8 scale diffs. I use 3k(rear) and 5K(front).
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
crazyjr
crazyjr's Avatar
01.29.2009, 03:48 AM
thanks George, There isn't any problems with the steering with that setup. I just want more aggressive
George16
Supermaxx
George16's Avatar
01.29.2009, 04:55 AM
No problems with steering at all. Then again, I'm also using a Hitec 5955TG servo for steering. You can raise the front diff oil to 7K if you want to. Use them as your baseline and go from there.
Revo with OS .18TZ
Hardstyle
Hardstyle's Avatar
01.29.2009, 10:53 AM
Yeah, Imo too 20,000 front and 10,000 rear is too stiff setup. Im using in my g2r Front 7k & Rear 5k. It handles very well now, but other hand im not a racer.
Don't forget the swaybars too, increase the handling quite. But I think you already knew it
Don't forget pics
TDC57
TDC57's Avatar
01.29.2009, 02:00 PM
Nothing!.. Hahahahaaa..
George16
Supermaxx
George16's Avatar
01.29.2009, 08:21 PM
Speaking of swaybars, I like the Tekno better than the traxxas swaybars.
Revo with OS .18TZ
Hardstyle
Hardstyle's Avatar
01.30.2009, 01:44 AM
+1 to that. On other hand I don't have experience on traxxas ones, hehe. Heard something that traxxas rear sway needs some minor modding to get working properly.
crazyjr
crazyjr's Avatar
01.30.2009, 05:52 AM
Originally Posted by TDC57 View Post
Ok here you go, these were the last pics i got of my truck. as i had said, she's seen better days.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
crazyjr
crazyjr's Avatar
01.30.2009, 05:55 AM
I was meaning i had no problems with steering, with the thick fluid. I am currently running a cirrus 70 servo (about 250in.oz at 6v)
crazyjr
crazyjr's Avatar
01.30.2009, 05:56 AM
Don't forget pics
swaybars are in the equation, I forgot to add them. I like the techno as well
TDC57
TDC57's Avatar
01.31.2009, 02:52 AM
Please mine has seen better days too but with a little hard work it all works out the same..
P.S.
Yes defiantly go with the Techno sway bars.. (Front and rear)..
George16
Supermaxx
George16's Avatar
01.31.2009, 03:30 AM
Only on the Nitro Revo.
Revo with OS .18TZ
Hardstyle
Hardstyle's Avatar
01.31.2009, 01:41 PM
Ok. feistyacorn had some issues with the trx rear sways in g3r. Dunno then.. But it was just matter of couple washers
http://www.rc-monster.com/forum/show...8&postcount=24
feistyacorn
feistyacorn's Avatar
02.09.2009, 05:01 PM
Ya, I did have a little issue with them hitting the top rear plate. Its not to hard to fix. I havent tried the tekno ones so I cant speak for them, but I do like the traxxas ones.
Good luck on the rebuild crazyjr, I cant wait to see the progress.
