SV6000
SV6000's Avatar
02.04.2009, 06:23 AM
Once the diffs are run in you need to shim them again. Make sure the pinion is seated all the way. The way i shimmed mine was as per the manual and i am having no trouble at all. Just follow the manual
Jason
02.04.2009, 08:07 PM
anyways I would give a try to this gears for the front and rear diffs...
http://www.greathobbies.com/producti...od_id=HBSC9010
and
http://www.greathobbies.com/producti...od_id=HBSC9009
I think it would direct fit!
Jason
02.04.2009, 08:08 PM
and
02.04.2009, 08:26 PM
Duplicate threads merged...
Jason
02.06.2009, 11:53 PM
sorry lol
so guys what the best gearing for running on 4s with 2370kv motor ?
George16
Supermaxx
George16's Avatar
02.07.2009, 06:47 AM
Start with 46/13.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Jason
02.07.2009, 03:40 PM
do you think 50/13 would be overgeared or undergeared ?
George16
Supermaxx
George16's Avatar
02.07.2009, 03:52 PM
undergeared
Revo with OS .18TZ
Jason
02.09.2009, 05:43 AM
are you sure ?
George16
Supermaxx
George16's Avatar
02.09.2009, 06:10 AM
I'm running 50/15 and my temps are the following:
ST-RR
50/15, 5S
ESC – 104
Motor – 131
Batteries – 100
However, give it a try first and see what the temps are then just use the guideline below.
I got this from one of the posts here in RCM:
Although not always true, a rule of thumb is:
Hot motor, cool controller, cool batteries = undergeared
Cool motor, hot controller, hot batteries = overgeared
Warm motor, warm controller, warm batteries = happy components
hot motor, hot ESC, and hot batteries = overgeared
Hot, warm, and cool vary as well, so here's another general rule:
Hot for a motor = generally over 160F (71C)
Hot for a controller = generally over 150F (66C)(or "thermal" range for the controller)
Hot for batteries = generally over 150F (66C) for nimh, 130F (54C) for lipo
Warm for a motor = generally 100F (38C) through 150F (66C)
Warm for a controller = generally 100F (38C) through 130F (54C)
Warm for batteries = generally 100F (38C) through 130F (54C) for nimh, ambient temp through 120F (49C) for lipo
Cool for all components = generally ambient temp and up to 10 degrees F (5.6C) more
The reasons the above are not always true are numerous, but may include:
Sticky drivetrain - will put un-necessary strain on electronics whether geared correctly or not.
Poor quality batteries - batteries will heat up regardless of gearing.
Wrong motor for the application - will put un-necessary strain on electronics whether geared correctly or not.
Wrong controller for the application - will put un-necessary strain on electronics whether geared correctly or not.
The list goes on, but this can give you an idea of things to watch for.
Revo with OS .18TZ
Jason
02.09.2009, 06:23 AM
thanks for this guideline bro
Jason
02.10.2009, 07:36 PM
which setting do ya use guys in mamba esc with your kyosho st-r the ideal one ...
for :
brake amount
punch control
start power
drag brake
reverse throttle
motor timing
George16
Supermaxx
George16's Avatar
02.11.2009, 05:46 AM
My settings:
brake amount - 50%
punch control - 50%
start power - Low
drag brake - Disabled
reverse throttle - 50%
motor timing - 10%
Revo with OS .18TZ
Jason
02.13.2009, 07:13 AM
stock brake curve and throttle curve right ?
im just back to upgrade my mamba max esc firmware to 1.20 better than the 1.17 one ?
and do ya use Porportional w/ reverse lockout or Forward to Brake to Reverse ?
George16
Supermaxx
George16's Avatar
02.13.2009, 07:17 AM
I'm using stock brake and throttle curves
1.20 is way better.
Revo with OS .18TZ
