e-mike
e-mike's Avatar
02.08.2009, 01:30 PM
For the motor to smoke running with or without a load just simply means something failed within the motor. The only part of the motor that would cause it to smoke is the copper winding. Now the heat issue only came because you held the throttle for too long. It doesn't matter if you applied half a throttle. When a wind shorts out, you get heat. The good thing I hope is that your ESC came out ok as some times it will fail too. Most motors will never reach a high enough AMP unloaded to cause anything to fail like this. So one of the phase failed and the cause could be that it was due to fail or the ESC made a mistake switching the wrong phase.
right lutach...but my esc still running great...(i only test my set-up about 30sec) and my motor come realy hot fast...no damage on the esc
i think thi is the rust who suround the metal part inside the motor and now the electrical magnetic force couldnt make is job....so this is causing my issue,,,like ive said 4 day ago all running very well,,,,i opened my motor and a lot of rust are sticked on the stator(visible place)...
D8t on juice!!
