skellyo
skellyo's Avatar
02.09.2009, 07:47 PM
Originally Posted by marcus View Post
No, the Flux ESC only has 1 Pos & 1 Neg input, unlike the Novak ESC's which have dual inputs and which you can frig like that.
The HPI wiring is perfect until you want to do this particular task. Ho-Hum
It still works the same way though. If you series the packs into the Eagle tree, you have 4-6S input, which goes out of the Eagle Tree as well. Take that output to one of the Deans on the Flux...does not matter which one. Take the other Deans on the Flux and Jumper across it. You have just made it a wire. Now your ESC sees the full voltage output out of the Eagle Tree. Here's a diagram:
