azjc
02.13.2009, 10:50 AM
Originally Posted by fastbaja5b View Post
Ok I got a Neu 1515 2050kv, it's a 60mm long can, so is that the 2d? - no wait been told it's a Neu 1515 2.5d
What gearing should I run with the standard 2 speed transmission. Also have a Robinson Racing steel wide range gear set on order and have alloy diff cups done, anything else need beefing up?
you have a 2d and the length of a Neu 1515 is 68 mm, I would also suggest the mod to remove the 1st gear and lock the tranny in 2nd, I used to have a converted 3.3 Revo with a 1515 2.5 d on 6s lipo with stock diffs and drivelines and never broke anything, it will be ok as long as you dont go WOT from a stop ( this is where your amp draw and physical stress on you drivetrain is the greatest)
