Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
Wild YFZ 450
yfz 450.
Wild YFZ 450's Avatar
03.21.2009, 09:21 PM
Yea thats what it should be with the tranny locked into second..Heres the guide
Here it is.. How to lock a Jato Transmission into 2nd gear.. I will be showing the "Pin method" There is a few others though..
First step is take apart the transmission and the "Centrifical clutch piece..Should look like this
Next you can drill 1 or 2 holes for the Pins..Make sure you go far out enough so it doesn't get in the way of the Bearing and so the gear is the thickest on the outside.. Just make sure you don't drill through it.. You can even use the bearing as a guidelin..You can drill either one or 2 I used only 1 since I am using 1/8 wheel pins..It should fit snug...
Then put the gears back in. Remember you can Take out the first gear so it will be less rotating mass.. Just make sure you keep the one way bearing in there as the spacer...
then slap it all together..
Throw in you battery[&:] ( or fill your tanks[:)] ) and have fun driving..
  Send a message via AIM to Wild YFZ 450
truggyracer1
truggyracer1's Avatar
03.21.2009, 09:36 PM
thanks i'm hoping its done already!
Z-Fire
03.22.2009, 07:11 AM
I just converted my Jato. I put the single speed in it. Does anyone know the ratio of that?
Wild YFZ 450
yfz 450.
03.22.2009, 01:54 PM
Look it up or use Brian G's speed calculator andit will have the ratios preset.
03.22.2009, 02:24 PM
Welcome to the forums Z-Fire. FYI: The ratio is 2.0667:1. And the calculator Wild is talking about is here.
Wild YFZ 450
yfz 450.
03.22.2009, 10:19 PM
Thanks for posting that. If I recall correctly you had a E-jato.. Mind posting it?
Z-Fire
04.04.2009, 08:01 AM
Thanx Brian,now I just need to save up for a BL system(The test run went good with old left-over brushed stuff.
03.22.2009, 10:20 PM
Here it is: http://scriptasylum.com/bl_conversions/_jato_v2.html
Wild YFZ 450
yfz 450.
03.22.2009, 10:24 PM
nice, but for some reason the pictures wont show up :'(
03.23.2009, 01:26 AM
Hmm. They are working fine now...
whitrzac
Can't catch this...
whitrzac's Avatar
04.03.2009, 09:08 AM
how is the motor mount plate mounted??
04.03.2009, 01:07 PM
Do you mean in my setup? If so, the mount uses the existing nitro holes and adjustment method.
whitrzac
Can't catch this...
whitrzac's Avatar
04.03.2009, 01:51 PM
you used motor clamps that a lot of boat/airplane guys yous, right??
'm more interested in how Wild YFZ 450 attached the e-maxx plate to it
04.03.2009, 01:59 PM
Sorry, your post was after mine, so I wasn't sure.
whitrzac
Can't catch this...
whitrzac's Avatar
04.03.2009, 07:23 PM
I finaly got to look at the pics of yours...
2 questions
does the chassis flex cause any problems??
any chance you can make another one??
