js058515
Thank You Brushless Gods!
js058515's Avatar
02.21.2009, 09:11 AM
Originally Posted by derek_18mt View Post
I am thinking i of getting the (TEKIN RX8 1700kv combo) run it on 5s lipo..maybe preorder one this wednesday BUT what does it have over the MMM that makes it more expensive?!!!! Worked ton of extra days just for this conversion:D
Will 1700kv on 5s be good? I was told it will be a very efficent setup
http://www.impaktrc.com/product_info...oducts_id=3076
It sounds like your a track guy so if you look at the chart on the above page you will see that a 5S battery with a 1700kv will give you about 31k which is perfect for track use. Efficient enough to help you with your run time goals. At least get 5000 mah and be sure to check the weight of the pack when you get to larger mah packs.
I had an ST-RR with Dan's RC Product Design conversion running on 6S 4000mah using a Neu 1512 2y 1400kv with 17/50 gearing getting me almost 20 mins. Not a lot of people like the 1512 for the Truggy, but the temps were good, weighed in a little lighter than a 1515, and still had tons more power than I needed. I have a pretty good throttle finger so I had a lot more efficiency with that too.
The only thing I would be worried of is that the Tekin has not been tested by the consumer yet. I too am eye-balling the motors and the speed control but won't move until the forum folks give us the dirt. I have gone through 3 MMM's and Nue motor when I got started with 1/8th electric (MMM's were my fault and all covered, Nue was covered and Impakt RC took care of me on that) now all my stuff works flawlessly. I still carry a spare MMM and Neu motor to the track. Downtime sucks especially when you just bought it, took the time to carefully install it and after a few minutes if goes up in smoke.
Anyways, sorry for the rant! Let us know what conversion your using and what motor you end up getting. Hope that helps some.
Losi 8B 1.0, Tekno V3, Direct-Drive, 13/48, RX8, T8 1400kv
Losi 8B 1.5, Tekno V3 w/clutch (3-shoe), 14/48, MMM, Neu 1512 2Y
Losi 8T 2.0, Tekno V3 w/clutch (3-shoe), 14/48, MMM, T8 1550kv
