ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
02.21.2009, 11:25 PM
Not really. A setup using X voltage geared for Y speed will not gain anything by simply changing motors unless their efficiency is different.
OK so I have been trying to get this right and I thought that I had...
He asked precisley what I was thinking; I got a MMM and a medusa 36-70-1600 to run 6s geared for 45, instead of getting the CC 2200kv Combo (on 6s, geared for 45) because I thought it would be a "more efficient setup". Of course the CC Combo would be geared lower, and the Medusa geared higher to net the same speed but the major factor for me would be the medusa is spinning 35,000 rpm to reach max speed, while the CC neu would be spinning at nearly 49,000 rpms. I was under the impression it is to have a "sweet spot" to get the motor at the prevent bearing stress and a hot motor...
Anyway I already took the dive on the Medusa and had a first run today, it was a blast about 25 minute run and the motor got to about 145 after it all. But maybe I could get the CC Neu from mike and have Deuce,.. Lemme know what you guys think
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
02.21.2009, 11:52 PM
I would say that a lower kv, like 1600, for larger motors such as the 1521 and 80mm medusa is the way to go. You get more torque from the longer motor, and lower motor rpm generally leads to better temps, and increased component life.
Now you may want to stick with a higher kv for a smaller motor, as the increased rpm will help out with less torque. This assumes you are running the motor in a heavier MT.
I run hacker c50 xl motors (longer than a 1515, but not quite a 1521) in 10 and 11 turns. Those are both near 1600kv, and work well in my heavy lst2. I have a 1521 to test as well, just waiting on some hex pins for the 20mm hubs so that I can run taller lst2 wheels/tires. And some al knuckles too.
Burnsi
02.22.2009, 11:51 AM
hmm, is anybody here who can check the cc against a medusa 70 or 80 with 1600kv?
02.22.2009, 03:21 PM
Check for what? The CC motor is a good 4-5 motor. A 1600kv medusa 70mm motor on 6s should have similar performance to the ccneu if you run it on 4s. 5s on the ccneu will make more "power" due to higherr motor rpm (if you gear down for the same speeds).
A medusa 80mm will have more torque than the 70 or ccneu, and is a better choice for a heavier vehicle. So it will handle more load and put out more power.
IMO, the 80mm is the best bet for a lst. The 70 and 1515 are a bit small. They are good for lighter trucks such as emaxx and erevo. Even a savage is lighter than a lst. I generally go for a longer motor as they will run cooler, and my battery choices can keep up with the increased demands. I am going to a 1521 for the lst I have, just cause I want 45+ mph speeds.
