Reading.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Reading. - 02.22.2009, 08:48 AM
If I am reading that package correctly does it not say that is is for the T-Maxx 7.5 gears?? If so then I do believe that you either received the wrong bulks, or you ordered the wrong number.
SUPERMAXX YOUR LIFE.
RUSTED
02.22.2009, 09:10 AM
no , it says that they use hyper 7 and inferno 7.5 gears , and the one im using is similar to the hyper diffs , i think i got the wrong bulks
RUSTED
02.22.2009, 10:50 AM
hhmm , i just compared it to the stock diff case , the hybrid seems to have a bigger bearing space , bigger openings and bigger internal space , i think the gear m8 be big , gonna check some other diffs in the hobby shop
