MetalMan
MetalMan's Avatar
02.23.2009, 02:59 AM
Prior to the bash I was able to remove the remainder of the mechanical brake components (linkages, pads, rotors) and that shaved a solid 2oz. off the truck. Next up was that nasty RX pack and the addition of the Hobby City HV UBEC, which I de-switched and added solder between the switch pads on the circuit board.
For those who showed up to the bash fully expecting to see this truck run, I apologize. Turns out the UBEC's switch turns it ON when the switch is in the open circuit position, hence why it wasn't sending any power to the RX.
Soon I shall throw this beast up on the scale. It wouldn't surprise me to see it just a couple ounces shy of breaking 12lbs.
02.23.2009, 03:56 AM
So how do you like the integy rear hubs? I have a pair coming for the flm savvy... Still debating whether to lock it in second, or wait and get the flux parts to convert it to single speed... I have to wait for the 1521 smooth can to show up, and the 10s lipos... The tranny forward chassis needs a certain amount of room to fit the batts, and my primary gearing has to work with that space too... Crap, waiting on parts again
